sherco 290
12 replies to this topic
#1 mattsherco290
    New Member
  • Members
  • Pip
  • 8 posts
  • Bike:sherco 290
Posted 18 November 2010 - 08:00 PM
hello there . right then i have a sherco 290 2000 model bought as project got told needed rebuild . ive stripped it down now and all bearings need replacing i can get get all of them exept the big end bearings . i have to buy conrod kit apparently to get them but i dont want to spend this sort of money lol at the moment im hoping the crankshaft pin isd fine . so i want to split the crank measure bearings and match them up . copuld i do this i need help thanks matt
#2 chewy
    Advanced Member
  • Members
  • PipPipPip
  • 954 posts
  • Bike:Beta Evo 200
  • Club:Kingswood MCC......Wessex
Posted 18 November 2010 - 09:28 PM
There used to be people that can do this for you , it requires precice alighnment on re assembly! Try motor engineers in Yellow pages perhaps
#3 copemech
    Advanced Member
  • Site Supporter
  • 8,058 posts
  • Bike:Sherco
  • Club:NTTA, TXTC
Posted 19 November 2010 - 02:57 AM
First question is why you need to do this? Is there any percievable monement up/down in the exhisting one? Is it rough feeling when rotating rod? If so, you need a kit! Otherwise not! :rolleyes:
Ride it Like it was one of your old Girlfriends, If you still remember how!
#4 mattsherco290
    New Member
  • Members
  • Pip
  • 8 posts
  • Bike:sherco 290
Posted 19 November 2010 - 04:24 PM
yer minimal movement up and down and slihtly side to side . bearings are goosed lol do you know any cheap kits ? cheers ive sent crank away to get looked at gettin it reconditioned cheers
#5 copemech
    Advanced Member
  • Site Supporter
  • 8,058 posts
  • Bike:Sherco
  • Club:NTTA, TXTC
Posted 20 November 2010 - 04:06 AM
No cheap kits, bite the bullet on this! If it is done it is doone. Should always be some side to side, btw. Most cycle shope can press and true the crank, I done tons back in the day. Nothing too special here for a good tech.
#6 mattsherco290
    New Member
  • Members
  • Pip
  • 8 posts
  • Bike:sherco 290
Posted 20 November 2010 - 03:28 PM
hi mate yeah whats the rough cost of it now anyway mate ?? just incase they try con me haha and whats the best stuff to use to clean the engine and what are sherco like for riding power wise ? im new to it hah
#7 copemech
    Advanced Member
  • Site Supporter
  • 8,058 posts
  • Bike:Sherco
  • Club:NTTA, TXTC
Posted 20 November 2010 - 08:19 PM
Best I recall, we would charge for one hour's labor at the prevailing rate to press a crank.
Mineral spirits paint thinner(for oil based paint) is probably your best cleaner, then a blow dry. Anything too strong like laquer thinner will take the paint off the cases.
#8 mattsherco290
    New Member
  • Members
  • Pip
  • 8 posts
  • Bike:sherco 290
Posted 24 November 2010 - 11:44 PM
okay buddy thaanks , any help on rebuilding my engine now i need to find out torque settings and everything else to put it back together thanks mate help would be great ta matt
#9 tony27
    Advanced Member
  • Site Supporter
  • 620 posts
  • Bike:jarvis rep,ty250c
  • Club:manawatu-orion
Posted 25 November 2010 - 07:26 AM
Look at the top of the page for the service manual links, they have pretty much everything you could possibly need in them
#10 copemech
    Advanced Member
  • Site Supporter
  • 8,058 posts
  • Bike:Sherco
  • Club:NTTA, TXTC
Posted 26 November 2010 - 03:50 AM
If I had to give tips to anyone on these motors, they would be:
Scribe the shaft and nuts on the therr major components, Flywheel, Primary drive geer, and Clutch hub prior to disassembly. This makes it easy to bring them back up to original or ever so slightly beyond position and torque using a rattle gun for quick assembly. Without, one would need a flywheel holder and clutch holder to apply proper torque. Most critical being the clutch hub, which is less and will strip.
Go back with the Viton main seals from Splatshop, as compared to the standard nitrile.
Be sure you keep all your little washers in proper relation.
:rolleyes:
#11 mattsherco290
    New Member
  • Members
  • Pip
  • 8 posts
  • Bike:sherco 290
Posted 28 November 2010 - 10:40 PM
:rolleyes:
okay thanks buddy . can any1 help me i want a full gasket set for sherco 290 2000 model ive found 1 for 38 pounds . is that cheap what would you say trial riders
#12 copemech
    Advanced Member
  • Site Supporter
  • 8,058 posts
  • Bike:Sherco
  • Club:NTTA, TXTC
Posted 29 November 2010 - 05:20 AM
Could be, all depends upon what's in it! Once again, might call someone like Chris at Splatshop to compare.
Some gaskets you may not need, depending?
#13 mattsherco290
    New Member
  • Members
  • Pip
  • 8 posts
  • Bike:sherco 290
Posted 03 December 2010 - 08:11 PM
hey there right alpha bearings have got my crank , i need a conrod kit unless i get recondition crank from somewhere if its possibly cheaper ?? any help ?
