Tyre psi
6 replies to this topic
#1 Stilly
    Member
  • Members
  • PipPip
  • 51 posts
  • Bike:Sherco
Posted 15 December 2010 - 05:24 PM
Hi all just wondering what psi should I be running in my front and rear tyre, I have had around 7psi in both, is this too much or not enough,
#2 BenBeta23
    Advanced Member
  • Site Supporter
  • 889 posts
  • Bike:Beta Evo 300 Factory
Posted 15 December 2010 - 05:31 PM
I run 4 1/2 in the rear and 5 1/2 in the front, Depends on your weight though really.
Trials UK
2011 Beta Evo 300 Factory 2T
#3 EastCoastHopper
    Member
  • Members
  • PipPip
  • 41 posts
  • Bike:2006 Sherco
  • Club:Rock and Roll Trials Club
Posted 15 December 2010 - 05:40 PM
I run between 3 and 4 psi in the rear and 5 to 7 in the front. If it's muddy and really slippery I run a bit lower, if it's dry and rocky, I run it a bit higher. I no longer use a gauge, just my hand. I like the front to be fairly firm and the rear I can put my thumb against the center of the tread and push it in about halfway to the rim. BenBeta23 is right about the weight thing too. If you're heavy and run it too soft, you risk denting the rear rim and getting a front flat.
Edited by EastCoastHopper, 15 December 2010 - 05:41 PM.
AD ASTRA PER ASPERA
Keep your feet off the ground and keep reaching for the stars!
Facebook: EastCoastHoppers
#4 helloyes
    Member
  • Members
  • PipPip
  • 62 posts
  • Bike:Fantic 200
  • Club:zona 1
Posted 15 December 2010 - 07:22 PM
I run 6psi in the front and 2.5-3 psi in the rear seems to work down here in muddy gloucestershire !!!
#5 chewy
    Advanced Member
  • Members
  • PipPipPip
  • 954 posts
  • Bike:Beta Evo 200
  • Club:Kingswood MCC......Wessex
Posted 15 December 2010 - 07:45 PM
probably what the other guys said but also dont forget that ambient temperature makes a big difference as well cold tyres are stiff like old trials riders
#6 Stilly
    Member
  • Members
  • PipPip
  • 51 posts
  • Bike:Sherco
Posted 16 December 2010 - 02:50 PM
Thanks for the info I will try 4 rear and 7 front f now and go from there.
#7 Neo
    Advanced Member
  • Members
  • PipPipPip
  • 920 posts
  • Bike:250 2006 (07 frame)
Posted 18 December 2010 - 09:44 AM
Tuning tyres is like tuning suspension and one effects the other too. Be aware of the limitation and try-test, try-test, try-test, try-test, try-test, try-test, try-test, try-test!! :icon_salut:
Best of Xmas balance to you :madnoel:
Neo
My Bike ....www.trialscentral.com/forums/garage/vehicle/516-sherco-250-2t-racing-red/
TRIALS....It's not life or death....It's much more serious than that!!
