piston change on 4rt
#1
Posted 10 January 2011 - 05:43 AM
#2
Posted 10 January 2011 - 09:34 AM
Comes to bits ok but struggled to get it back together in the frame.
#3
Posted 10 January 2011 - 10:50 AM
Give me a ring if you have any problems.
Regards,
Caroline
#4
Posted 10 January 2011 - 02:40 PM
Edited by SportSawyer, 10 January 2011 - 02:45 PM.
#5
Posted 10 January 2011 - 04:06 PM
SportSawyer, on 10 January 2011 - 02:40 PM, said:
#6
Posted 10 January 2011 - 05:34 PM
You need to make a little tool as per diagram to release tension on the cam chain. There are marks then on cam shaft sprocket when rebuilding.
Worth taking off the bash plate and side front frame arms as a matter of course. You will need to support the bike via the back frame cross member or footrests to allow engine to drop slightly lower.
Careful when installing cam guides into bottom end of engine as can miss bottom locating lug.
Drain rad etc first.
All fully documented in engine rebuild section of the manual.
If you get stuck I'm sure there are enough people on here to help
#7
Posted 10 January 2011 - 07:25 PM
#8
Posted 10 January 2011 - 08:16 PM
#9
Posted 10 January 2011 - 09:25 PM
Page 3-5 valve clearance
Page 4-36 cam chain setting - reads a little confusing but I think it makes sense when bits are in your hands but if somebody can explain it better than the manual might help you.
Page 4-17 special tool to lock cam tensioner
Best of luck
#10
Posted 10 January 2011 - 09:51 PM
if you need to wait for parts you could forget something
manual is very good (i guess only trials bike with a decent manual)
work in a clean space and put your parts in little pots like they came of the bike
good luck its not so hard
best regards bob
#11
Posted 10 January 2011 - 10:06 PM
#12
Posted 11 January 2011 - 03:48 PM
#13
Posted 11 January 2011 - 05:20 PM
Basic mechanic skills, care and attention to detail, some photos and good organistion would normally suffice
#14
Posted 11 January 2011 - 07:20 PM
#15
Posted 11 January 2011 - 09:55 PM
dye29, on 10 January 2011 - 05:43 AM, said:
When you have the cylinder off, look very carefully at the front, top of the bore, about 5mm
below the top. With the "slipper" type pistons, a worn skirt will cause piston rock and often
wear the plating through on the "thrust side" of the cylinder. A very slight amount of piston
pin "offset" helps to keep this from happening, but a well worn piston can damage that area.
Jon
