Curing a Leaking Fuel tank
francley40
I'm sure I'm not alone with this problem - and apologies if it's been covered before.
The tank on my '03 250 Pro has a small leak which is a pain.
The previous owner has tried to repair it with that 'plastic metal' two part epoxy whateveritis stuff.
Which hasn't really worked....
I was wondering if anyone has had success using the liquid 'tank seal' products that're on the market?
If you have can you tell me what the procedure is, too, please?
Many thanks.
Many thanks.
this stuff supposed to work on plastic tanks, may be tough to get the failed stuff out though
http://www.caswellplating.com/aids/epoxygas.htm
Is this at the rear of the tank where the Air box bolts "foul" it. We had that with an 06 tank. I had the tank welded by a local firm who do it in inert gas so the tank does not blow up. The Company is in Leeds and is called Startright. They have a website at www.startright.co.uk
Get it Tig welded
Wash it out well several times, and then take it to local (friendly) aluminium fabricators
Ive just had tank repaired the same way for a tenner! :thumbup:
It does ruin the paint finish though
Edited by Monty_Jon
