rebuild help please
4 replies to this topic
#1 yamxj
    Member
  • Members
  • PipPip
  • 34 posts
  • Bike:gas gas 280
  • Club:barnsley
Posted 09 February 2011 - 07:39 PM
i am in the middle of putting new crank bearings in my 2000 280 i just have a couple of questions . do i use gasket glue and how do i set the timming thanks
#2 JSE
    Advanced Member
  • Members
  • PipPipPip
  • 2,026 posts
  • Bike:Gas-Gas Pro, TY350s
  • Club:NEOTT-Life member, Texhoma Trials Club, AMA-Life Member
Posted 09 February 2011 - 11:13 PM
Put the centercase gasket on dry and you do not have to set the timing, it's set mechanically and, under normal circumstances, does not change.
Jon
Probably ought to expand on the timing issue. Provided you marked the stator plate position, just set it back to it's original spot. Even if you didn't mark the stator, you usually can tell where it was by the depressions the mounting screws made on the plate so just center the depressions over the screw holes.
Edited by JSE, 10 February 2011 - 03:08 PM.
#3 yamxj
    Member
  • Members
  • PipPip
  • 34 posts
  • Bike:gas gas 280
  • Club:barnsley
Posted 10 February 2011 - 09:14 PM
thanks for that i did mark the position the only thing now is i am having trouble getting clutch case on seems like kick start spring could be a problem any ideas ?
#4 JSE
    Advanced Member
  • Members
  • PipPipPip
  • 2,026 posts
Posted 11 February 2011 - 01:37 AM
If you use the kickstart lever as a tool to push/turn/latch the racheting mechanism it's a little easier. I think there's usually a collar that acts to keep the coil spring from distorting and it usually has a slot in it that sometimes gets out of alignment and the shaft will not seat in completely.
Jon
#5 yamxj
    Member
  • Members
  • PipPip
  • 34 posts
  • Bike:gas gas 280
  • Club:barnsley
Posted 11 February 2011 - 06:22 PM
you were spot on the spacer with the slot in had moved only a couple of hours untill i saw it now i have lost one of the spring clips that hold the piston in place have you ever done somthing ya wished ya had'nt started
