Swinging arm bearing removal.
cabby
Sorry for the crude drawing of the swingarm but it was only done quick!!
Just a simple pusher about .1mm narrower that the bearing outer race and .1mm narrower than the bearing inner race. Either use a press or hammer to push em out
No that's perfect....thanks
But I assume you drove out both bearing cadges at the same time like this?
Best of balance.
Neo
yep,both at same time, then used a long bush and pressed the bearings in from each side with the bush in place so they would be aligned right
