SWM 320 burning engine oil
7 replies to this topic
#1 ChrisB7
    New Member
  • Members
  • Pip
  • 9 posts
  • Bike:SWM 320
  • Club:Lancs County
Posted 25 July 2011 - 06:00 PM
I have recently replaced the crank seals and also the large O ring on the disk valve cover but engine oil still seems to be getting through into the cylinder. Bike smokes a fair bit as a result. Does anybody have any ideas of what else I can do to stop the engine oil getting through?
#2 pedronicman
    Advanced Member
  • Members
  • PipPipPip
  • 312 posts
  • Bike:300 PRO
  • Club:Too many
Posted 25 July 2011 - 06:49 PM
I would be 100% sure that the gearbox oil is passing between the centre crankcases
as it is only sealed by sealant as thhese engines aren't fitted with a centre gasket.
If you split the engine to fix it make sure you use a good quality case sealant
like THREEBOND engine sealant.
Do not use silicone houshold sealnt.
Cheers
#3 ChrisB7
    New Member
  • Members
  • Pip
  • 9 posts
  • Bike:SWM 320
  • Club:Lancs County
Posted 25 July 2011 - 08:32 PM
Cheers
#4 ChrisB7
    New Member
  • Members
  • Pip
  • 9 posts
  • Bike:SWM 320
  • Club:Lancs County
Posted 25 July 2011 - 08:33 PM
Thanks for the advice, that's a job to be done over the next few weeks!
Cheers Chris
#5 Reginald
    Member
  • Members
  • PipPip
  • 98 posts
  • Bike:2 x SWM TL 320 1982;
  • Club:Rocky trials club; Central Qld.
Posted 26 July 2011 - 02:07 AM
Hi, from this conversation it sounds like crankshaft seals can be replaced without splitting the cases?? And how necessary is to rep;lace the rotary valve o ring as I am currently ordering parts and haven't included that?
Any advice welcomed.
#6 ChrisB7
    New Member
  • Members
  • Pip
  • 9 posts
  • Bike:SWM 320
  • Club:Lancs County
Posted 26 July 2011 - 11:15 AM
Hi, Yes I replaced both seals without splitting the engine. One seal sits in the disk valve cover and the other sits in the magneto plate that sits behind the flywheel. (the flywheel cover bolts to this plate) I replaced the O Ring in the disk valve cover just as a precaution even though the original looked ok. Obviously, I have been unlucky in my attempt to minimise the work as I now have to split the engine to replace the sealant. I originally thought that there was a gasket between the two sides of the engine.
Cheers Chris
#7 Reginald
    Member
  • Members
  • PipPip
  • 98 posts
Posted 16 October 2011 - 08:32 AM
Well with the help of Feetfun [thanks Dave] and some advice from Martin on locking the engine with a bolt thought the cases we replaced the clutch side oil seal - still leaking and burning oil - bugger - is it worth doing the rotary valve o ring? or could I be up for a spilt the cases job?
#8 Reginald
    Member
  • Members
  • PipPip
  • 98 posts
Posted 17 March 2012 - 12:58 AM
Well she's been dismantled recently and the induction valve cover o ring looked stuffed ie flat it also appeared to sucking air thru cases. Splitting the cases was worth while as kickstarter engagement dogs were chipped. Piston still standard and didn't need re bore - so new rings only.
gearbox and big end was fine [those main bearings are huge].
Looking fwd to having her back together.
