what oil is best
8 replies to this topic
#1 jamessut
    New Member
  • Members
  • Pip
  • 16 posts
Posted 02 October 2011 - 05:40 PM
Just wanting some advice about which is the best oil to use in my Gas Gas txt pro 2004, clutch fluid and gearbox oil as i am changing next week any advice would be appreciated. Thanks
#2 curt531
    Member
  • Members
  • PipPip
  • 58 posts
Posted 02 October 2011 - 06:16 PM
Hi, clutch must have a mineral based cluth/brake fluid in it or the seals wont last, gear box have ATF, personally I use a BP product in the clutch & Silkoline ATF in my gearbox on my 2005 Gasser, hope this helps :)
#3 JanDyb
    Advanced Member
  • Members
  • PipPipPip
  • 244 posts
  • Bike:280 Pro Racing 2011
  • Club:Trøgstad Trialklubb, Norway
Posted 02 October 2011 - 06:23 PM
Nono.. the mineral oil in clutch is from 2005, so unless the pumps are rebuild to use mineral oil, You should use normal brake fluid dot 4 (or 5) on a 2004.
ATF Dexron III works good in gearbox.
-Jan
#4 jamessut
    New Member
  • Members
  • Pip
  • 16 posts
Posted 02 October 2011 - 07:36 PM
Thanks for the replies, what would happen if someone before me used mineral oil instead of dot 4 reason I am changing it is clutch seems to be heavy compared to others and my forearms are like popeyes after a short time
#5 JSE
    Advanced Member
  • Members
  • PipPipPip
  • 2,027 posts
  • Bike:Gas-Gas Pro, TY350s
  • Club:NEOTT-Life member, Texhoma Trials Club, AMA-Life Member
Posted 02 October 2011 - 08:18 PM
-Jan
If the clutch is designed for mineral oil use, the top cap on the M/C will be a green color (black color for DOT-3/4/5.1).
DOT 5 is not compatable with DOT-3/4/5.1 fluid and is Silicone based.
Jon
#6 JanDyb
    Advanced Member
  • Members
  • PipPipPip
  • 244 posts
Posted 04 October 2011 - 11:44 AM
Jon is of cause right. Dot 5 and Dot 5.1 is not the same.
But..If Your clutch is heavy it probably is because Your clutch fibres are swelled. This makes the clutch pack too thick which again makes the moment for the clutch "fingers" wrong. (search the forum and you will find plenty of posts regarding this).
If you remove clutch cover you can easily measure this by measuring the hight of the "fingertips". It should be about 17mm. Thicker clutch pack means lower fingertips and harder clutch action. 0,1 mm difference in clutch pack makes 2 mm difference in fingerheights.
3 solutions:
1. Buy new clutch pack.
2. Adjust clutch pack by changing the metal plates in clutch pack to thinner ones. Trialendurodirect.com used to sell these in different thickness, but I dont know if they still do.
3. Carefully sand clutch fibres by using fine sandpaper (600+) on a glass plate. This can work but if you make fibres uneaven new clutch pack is only solution.
-Jan
Edited by JanDyb, 04 October 2011 - 11:45 AM.
#7 laser1
    Advanced Member
  • Members
  • PipPipPip
  • 452 posts
  • Bike:09 GG 250
Posted 04 October 2011 - 01:19 PM
Another improvement to any 05 clutch is to switch to the 06+ clutch spring. Its 20% lighter over your current spring and makes a huge difference.
#8 jamessut
    New Member
  • Members
  • Pip
  • 16 posts
Posted 04 October 2011 - 05:41 PM
Thanks for all the advice, going to measure the plates whilst I have everything drained.
#9 JanDyb
    Advanced Member
  • Members
  • PipPipPip
  • 244 posts
Posted 05 October 2011 - 06:42 PM
-Jan
Found the steel plates:
http://www.trialendu...plates_291.html
-Jan
