Front Tyres for TLR non competition
14 replies to this topic
#1 keychange
    Advanced Member
  • Members
  • PipPipPip
  • 290 posts
  • Bike:Cota 247T TLR200
  • Club:Coonabarabran
Posted 25 November 2011 - 07:31 AM
Tyre discussions appear never ending but that is probably due to the continued variation in costs. My TLR 200 has I think the original dual purpose block pattern (can't remember that make and it's raining too heavy to check) The old tyre is hard and cracked so I guess it's time to replace it.
I have Michelins on my Cota 247 and it does ride nicely but when I inherited the TLR I never envisaged it would be as competent as it is and so I went for a VeeRubber tubeless on the rear - what a bugger to fit that was - but it has given me no problems and good wear running around 7 psi.
I am not a competition rider - comps are all held too far away for me to be bothered ( the nearest I am aware of is 4 hours drive each way most much further) so I simply enjoy riding around where I live - mostly steep slippery trails with short periods of more testing rocks etc.
The Michelins are bloody expensive and considering the strength of the dollar are no cheaper now than when the AUD was 60 cent US. I found a Dunlop D803 listed for $58 by a crowd pretending to be Australian morepowerracing.com.au but turns out to be US and they want $180 postage!!! Real Aussie sites are charging $100+ plus postage for the D803- where as I can buy Pirelli MT43 for under $80 which is the same price as a VeeRubber. The point is surely any one of these tyres will be a big improvement of the tired old antique currently fitted.
Will I regret not spending near twice the price to have a Michelin front while still running the VeeRubber rear?
Edited by keychange, 25 November 2011 - 07:32 AM.
Cheers
Andrew in Oz
Wrinkled but not broken!
#2 chewy
    Advanced Member
  • Members
  • PipPipPip
  • 954 posts
  • Bike:Beta Evo 200
  • Club:Kingswood MCC......Wessex
Posted 25 November 2011 - 08:06 AM
g,day go for the pirelli mt43 they were all the fashion 20 odd years ago When your bike was new. I suppose its just coming into summer over there . From memory IRC are made in Japan they are thin carcass really flexible and may be competitive price wise over there.
#3 feetupfun
    Advanced Member
  • Members
  • PipPipPip
  • 1,380 posts
  • Bike:1963 to 1981
Posted 25 November 2011 - 09:00 AM
IRC fronts are good value in Australia and are much better to ride with than Pirelli fronts. I rate IRC fronts along side Dunlop fronts but not quite as good as Michelin fronts.
You put my Basil in the ratatouille?
#4 keychange
    Advanced Member
  • Members
  • PipPipPip
  • 290 posts
Posted 25 November 2011 - 10:08 AM
It's only $30 difference between IRC and Pirelli but what I read about IRC is VERY soft and I have this mixture of very soft wet ground and then very rocky then very muddy (we have 2 to 3 metres of rainfall and most of that is concentrated ex-winter) I was wondering of the IRC will handle the rocky stuff ok?
Cheers
Andrew in Oz
#5 feetupfun
    Advanced Member
  • Members
  • PipPipPip
  • 1,380 posts
  • Bike:1963 to 1981
Posted 25 November 2011 - 10:28 AM
My IRC fronts have been very slow to wear. The rubber feels same softness as Dunlop to me when new and carcass stiffness is also very similar to Dunlop ie carcass not as flexible as Michelin given same pressure. All proper trials competition tyres have softer rubber and are more flexible than the Pirelli.
I have never been able to wear out a front trials tyre before the rubber goes hard so maybe I'm not the right person to give an opinion about which competition trials tyre is best for intensive long distance trail riding.
#6 keychange
    Advanced Member
  • Members
  • PipPipPip
  • 290 posts
Posted 25 November 2011 - 11:35 AM
David
Believe it or not I make my living out of giving advice and I try to live by the adage - don't ask for advice unless you are prepared to take it. I know haven't always taken yours but I do respect it and so once again thanks and I will in this case go with the IRC ... now decide where to purchase ...
Cheers
Andrew in Oz
#7 jon v8
    Advanced Member
  • Site Supporter
  • 627 posts
  • Bike:HT5, TY Yams.
  • Club:Bath Classic
Posted 25 November 2011 - 01:02 PM
Cheeky blighter - I still have an MT43 on the front of my Yam,cant see anything wrong with them on the front.(I did get alot of stick from a certain member of my trials sub commitee cos I had one on the back until the Dartmoor two this year)
I'd go IRC,the grip is brilliant.
#8 Woody
    Advanced Member
  • Site Supporter
  • 2,650 posts
Posted 25 November 2011 - 09:49 PM
The IRC is obviously a better tyre and at only $30 difference is the better choice. It will handle all the terrain you mention no problem.
However, as you're just playing or trail riding and not riding events then an MT43 will be fine if you want the cheaper option. We used to use them in the 80s in all types of events, they weren't as good as a Michelin on rocks but they performed well enough.
You wouldn't want one for serious competition these days as things have moved on, but for what you want, no problem.
#9 keychange
    Advanced Member
  • Members
  • PipPipPip
  • 290 posts
Posted 01 December 2011 - 03:56 AM
I ended up going with the Dunlop - the guys selling IRC wanted $140 including postage where as the Dunlop cost me $117 - ok call me a tight ar5e.
Thanks everyone for your input
Cheers
Andrew in Oz
#10 keychange
    Advanced Member
  • Members
  • PipPipPip
  • 290 posts
Posted 07 January 2012 - 07:48 AM
I finally got round to fitting the Dunlop (had a busy Xmas) and with the aid of two shiny new tyre levers it was the easiest tyre change I have ever done. BUT - I can't get the tyre to sit straight in the rim. Pumped it right up and let it down , bounced it, pushed it , pulled it and poured buckets of soapy water but it just won't sit straight on the rim.
I have a tubeless rear and that needed about 80psi to get the bead to pop in ..... but I wouldn't expect that on the dunlop. I did a new michelin on my Cota recently and had no problems...any tips appreciated.
Cheers
Andrew in Oz
#11 feetupfun
    Advanced Member
  • Members
  • PipPipPip
  • 1,380 posts
  • Bike:1963 to 1981
Posted 07 January 2012 - 08:12 AM
Andrew are you talking about a front Dunlop or a rear Dunlop that won't sit straight?
#12 keychange
    Advanced Member
  • Members
  • PipPipPip
  • 290 posts
Posted 07 January 2012 - 08:31 AM
It's the front tyre .. I have been reading more tips etc and can't see anything I have forgotten. I think tomorrow I will deflate and pour 50/50 detergent in the rim and then inflate again. The inside rim was in good condition compared to corrosion on the rear but there are plenty of tyre iron marks from past changes and maybe these are grabbing the tyre ... I did give it a very good clean with wire brushes but maybe there is an old (or new) scuff catching...but the problem isn't in one spot - I can resit the tyre and it is then out of position eslewhere :(
Cheers
Andrew in Oz
#13 spawtydawg
    Member
  • Members
  • PipPip
  • 57 posts
  • Bike:Yamaha ty175
  • Club:Hawks mcc
Posted 08 January 2012 - 12:17 AM
Hi, think you're just going to have to persevere on this one, plenty of lube and it should pop
on ok unless of course the rim is horrendously distorted. Good luck with it.
#14 spawtydawg
    Member
  • Members
  • PipPip
  • 57 posts
  • Bike:Yamaha ty175
  • Club:Hawks mcc
Posted 08 January 2012 - 12:22 AM
That might explain your results :rotfl: . Only joking you kicked my a*se big time last time out :) .
#15 keychange
    Advanced Member
  • Members
  • PipPipPip
  • 290 posts
Posted 08 January 2012 - 12:49 AM
Yep lots more soap and 35 psi and she is sitting sweet :)
Cheers
Andrew in Oz
