Help i've submerged my Sherco
#1
Posted 06 December 2011 - 09:03 PM
I recently bought a 2003 Sherco 200cc and today on my second outing whilst riding through what i thought was a shallow river i suddenly hit a deep part submerging my bike for around 40 seconds, needless to say the engine cut out. Once back on dry land i tried kicking it off and had no joy. After draining the Exhaust Air Filter and removing the Spark plug and kicking it over i thought we be able to fire it up again but no such luck
After a couple of hrs tinkering we managed to fire it up but when i applied more throttle is seemed to bog down as though it was starved of air or fuel and cut out
i removed the air filter and changed the fuel and and after a while iwe managed to get it running again but it still seemed starved of fuel or air. I managed to ride it back to the car which was about 1/4 mile away on low throttle and coughing and spluttering along.
I'm just after some ideas as to what i need to do now i.e what parts to strip down and where else they may be water trapped..
and the final big question HAVE I COMPLETLEY BUGGERED MY BIKE or will it be back to working order in no time????
Cheers Jimmy
#2
Posted 06 December 2011 - 09:15 PM
#3
Posted 06 December 2011 - 10:26 PM
#4
Posted 07 December 2011 - 12:05 AM
#5
Posted 07 December 2011 - 12:10 AM
My uncle went up a massive hill and overshot it, landing it in a pond. The bike was completely under water.
It was a Sherco too!
My dad stripped the whole bike, turned it upside down in the garage to dry out for a few days. Then basically whilst it was all apart serviced the whole bike, new oil... absolutely everything was done to it and the bike still lives!
So no I wouldn't say you have completely buggered your bike, because if my dad sorted his I'm sure you can get yours running again.
Crowthorne Cycle Trials - http://crowthorne-ct.co.uk
#6
Posted 07 December 2011 - 01:00 AM
BTW it's best to get them started and ridden right away to dry every thing out
Canondale MX440
Cannondale Cannibal 468
Cannondale Cannibal 505
ATK cannibal 440
GasGas 280
GasGas 300 pro
Ossa tr280i
50/50/90 rule - Anytime there is a 50/50 choice , there's a 90% chance you'll pick the wrong one
#7
Posted 07 December 2011 - 04:01 AM
#8
Posted 07 December 2011 - 04:18 PM
Permanent damage? I've known many flooded bikes never had any problems from it and the odd few have ignition, main bearing or big end failure in the following weeks.
Cheers
#9
Posted 08 December 2011 - 09:53 PM
#10
Posted 09 January 2012 - 08:42 PM
I got the Sherco stripped down and all dryed out with the help of the wifes Hair dryer. While i was at it i give everything a good clean up and changed the Trans Oil. The bike is now back together but still cuts out when i give it a fist full of throttle and it is also a Pig to start.
I can get the revs up to full throttle if i gently run it up slowly but when i give it a big hand full it just dies on me also i get smoke coming out of the air filter.
I believe the problem to be a plugged exhaust as when i taken the sliencer off it started first kick every time i couldn't mess about with it too much as i live in a quiet close and it sounded like we were being bombarded with gun fire ha ha..
The bike revved up a bit better but sounded like it was gonna cut out so i hit the kill switch.
I'm going to take the bike somewhere remote tomorrow and give it a blast without the sliencer to see how she goes.
Does the Plugged exhaust sound about right or is there something alse i need to be looking at
Cheers guys i will let you know how i get on tomorrow
Jimmy
#11
Posted 09 January 2012 - 08:55 PM
It revved cleanly after that and finished the day with no problems.
Alan
#12
Posted 09 January 2012 - 09:02 PM
Alan
Hi Alan
Thanks for the reply i've already had the carb fully stripped down and cleaned out if i dont get any joy tomorrow i will do it again and give it a blast with carb cleaner as i only washed it out with hot water and then petrol
Regards Jimmy
#13
Posted 10 January 2012 - 02:58 AM
Regards Jimmy
Never seen a muff that plugged! Get a fresh plug. If the motor had sudden stoppage, flywheel key could have sheared. Just thoughts.
#14
Posted 11 January 2012 - 06:58 PM
#15
Posted 12 January 2012 - 04:23 AM
Jimmyparko, on 11 January 2012 - 06:58 PM, said:
Well, that is good to hear in a way, as I admit I was a bit hesitant about going there as I have never seen the stock reeds break, yet another lesson learned, but it must have taken some really hard water force to do it! Did you find the pieces?
Pity, I have some stock reeds I could send you, but it would take a week or more for you to get them!
Thank s for the update!
