changing tyres
15 replies to this topic
#1 mill9898
    Member
  • Members
  • PipPip
  • 43 posts
  • Bike:gas gas 300 raga
Posted 21 January 2012 - 07:55 PM
i want to change the rear tyre ,which is the best?. and i am used to changing enduro wheels with mooses,are trials tyres easier or harder to change than these?
#2 Pete_Scorpa3
    Advanced Member
  • Site Supporter
  • 1,440 posts
  • Bike:Scorpa SY250
  • Club:Stratford-Upon-Avon MC&LCC
Posted 21 January 2012 - 08:01 PM
Much easier than a knobbly with a moose fitted, but only once the bead is broken!
#3 gjbiker
    Advanced Member
  • Site Supporter
  • 525 posts
  • Bike:250 GG, 250 Beamish
  • Club:BAMCC
Posted 21 January 2012 - 08:14 PM
:agreed:
Have a look here to help you decide which tyre buy- Click here for black round rubber things
GJ :wacko:
He who dies with most toys wins.
It's all in the wrist action.............
#4 pindie
    Advanced Member
  • Members
  • PipPipPip
  • 350 posts
  • Bike:2007 Beta Rev3 200
Posted 21 January 2012 - 08:29 PM
Stick with Michelins. You can't go wrong.
Leave the wheel and tyres in a warm place before fitting. If you can do knobs and mooses you will have no problem.
#5 Al_Orange
    New Member
  • Members
  • Pip
  • 23 posts
  • Bike:2001 Beta Rev 3 270
Posted 24 January 2012 - 08:54 PM
Can you fit tubeless without a donut and air compressor or is that wishful thinking?
#6 Nigel Dabster
    Advanced Member
  • Members
  • PipPipPip
  • 6,573 posts
  • Bike:Gas Gas Bultaco 340
  • Club:Milton Buzzard MCC,Richmond MC
Posted 24 January 2012 - 08:59 PM
a beeder means you dont need a compressor
#7 manx2day
    Advanced Member
  • Members
  • PipPipPip
  • 309 posts
  • Bike:TMM Gas Gas 2011
  • Club:IOMYTC
Posted 25 January 2012 - 09:52 AM
push bike inner tube and a track pump! :thumbup:
Go Big or Go Home!!
MORNING!
#8 Al_Orange
    New Member
  • Members
  • Pip
  • 23 posts
Posted 25 January 2012 - 12:05 PM
Excellent!! Nice one. Any idea what sizes of tube are best? diameter and width. Do you take the valve stem out when you pump up the tyre? or is that not necessary?
#9 pindie
    Advanced Member
  • Members
  • PipPipPip
  • 350 posts
Posted 26 January 2012 - 07:13 PM
It's scary but you can fill with aerosol such as deoderant and light the gas with a taper. BOOM!. It's on the rim.
5 second blast and then light. Do not set fire to your tyre!
#10 mill9898
    Member
  • Members
  • PipPip
  • 43 posts
Posted 26 January 2012 - 08:37 PM
explain please?
#11 mill9898
    Member
  • Members
  • PipPip
  • 43 posts
Posted 26 January 2012 - 08:38 PM
could you explain how cheers jake
#12 jimmyl
    Advanced Member
  • Members
  • PipPipPip
  • 681 posts
  • Bike:Montesa 4rt 2005
  • Club:Neath
Posted 26 January 2012 - 08:51 PM
I've used a push bike inner tube as a tyre beader. Used 16" but is a bit tight. 17" or 18" may be better. Still needed a compresssor though
Normally get a Mich to go the rim jsut with compressor but IRC has proved a little more challenging.
Jimmy
#13 Al_Orange
    New Member
  • Members
  • Pip
  • 23 posts
Posted 27 January 2012 - 01:41 PM
Actually, I'm trying to talk myself into buying a compressor - at the moment I can only think of the following uses:
1. Fitting tyres
2. Blowing out spark plug holes (on 4 strokes)
3. pushing out brake caliper pistons
4. Cleaning Carbs
What else are they really useful for? Everything above can be achieved without one.
#14 2/4
    Advanced Member
  • Members
  • PipPipPip
  • 639 posts
Posted 27 January 2012 - 05:26 PM
1. Fitting tyres
4. Cleaning Carbs
I imagine they'd be equally useful for blowing out spark plug holes on a twostroke but would not recommend it as a method for any motor as it's likely to put dirt etc in to the motor. Better to use an old plug with a diagonal saw cut across the thread to clean a plug hole thread.
#15 gjbiker
    Advanced Member
  • Site Supporter
  • 525 posts
  • Club:BAMCC
Posted 27 January 2012 - 05:29 PM
Along with a tyre inflator and a blow nozzle for achieving the things you've mentioned (and numerous other tasks) I also have the following;
Spray guns for spraying things
Nail guns for nailing things
Cut off tool for cutting things
Grinder for grinding things
Needle gun for needle gunning things
Chisel for chiselling things
Stapler for stapling things
Brake bleeder for bleeding things
Paraffin gun for, well washing oily things and lubing the underside of Land Rovers
Plasma cutter (needs compressed air)
Impact gun for impacting things
Ratchet for ratcheting things
Grease gun for greasing things
Sander for sanding things
Die grinder for putting things in your eye when you forget to put goggles on......
etc etc etc
Yes you can probably achieve most tasks without a compressor but they fairly make life easier if you have one. If you prefer a challenge try taking the engine out your trials bike and fit it with pedals! 8 out of ten compressor owners prefer engines, the other two blow up air beds as a hobby :rolleyes:
Convinced you yet?
GJ :wacko:
