Need more power
Started by fatbastard, Jan 21 2012 08:04 PM
15 replies to this topic
#1
Posted 21 January 2012 - 08:04 PM
My son has just got an 125, he has been used to riding a Evo 200cc for last 9 months. He feels the bike has a real lack of power compared his 200cc and to 125cc Gasser's he has had a shot off.
An example 3rd gear hill, lack of power at the top the Sherco dies if you were to come off throttle then back on (requires a handfull of throttle and ping of the clutch). The same hill on Gasser you can come off throttle and back on with out it dying on you.
We can fully understand the difference between engine sizes but are the different manufacturers really going to make much difference. Could some people just prefer the power delivery of a Gasser or would it be the bikes just set up differently.
Would a High Compression Head and change Jets make much difference. I know some say change Carbs but on the flip side they require a lot more maintenance so probably prefer to stick with stock Carb.
Any advice would be much appreciated.
#2
Posted 21 January 2012 - 08:09 PM
hi comp head will help ,a s3 or simular front pipe will also help ,a larger rear sprocket might be all it needs
#4
Posted 21 January 2012 - 08:55 PM
I think the top lads run a 48T rear in order to pull a big third gear .
Ride it Like it was one of your old Girlfriends, If you still remember how!
#5
fat*******, on 21 January 2012 - 08:24 PM, said:
I hadnt thought about the front pipe, thanks.
What size of rear sprocket would you recommend ?
#6
Posted 21 January 2012 - 09:11 PM
Hi
Make sure you have a quick action throttle, the 125s cant respond like the larger capacity. Phone the importer he should help you with all the settings, and any mods you require. The 125s are great machines but need a lot of rider effort but in the long run he will really learn how to get the most of the bike,
Pete
Pete
#7
Posted 21 January 2012 - 09:26 PM
The bike had only had 3 hours use so it's as new. I think he had ridden the Gasser and it felt better engine wise. He quite likes the Sherco suspension wise but it's just lacking power on the bigger stuff.
Thanks for everyones input.
#8
Posted 21 January 2012 - 10:55 PM
Gearing?
Shercos seem to be longer geared..does the gasser have 6 speeds?
For the last time...it's not 'SUPPOSED' to have a seat.
There are two types of men in this world:-
1) Those who are Geordies and..
2) Those that want to be.
#9
Posted 22 January 2012 - 02:08 AM
None the 125's will pull a tall gear.
#10
Posted 22 January 2012 - 04:10 AM
Is it fresh? 125's do need more frequent piston replacements than the bigger bikes. Was speaking with one of the RYP team members last year during spring training and he was very excited about the power of his new 2011 125 then(Almost typed "he was gassed about the power...but realized that wouldn't have been right!)
Fantic 240,Fantic 309
Yamaha TY350,back home!
2011 Sherco 250
2009 Kawasaki KLX250S DualSport
2011 Sherco 250
#13
Posted 22 January 2012 - 03:21 PM
Couple of quotes in this topic I would love to hear the reasoning behind.
[quote name='petejohn' timestamp='1327180277' post='291782']
Hi
[/quote]
[quote htrdoug] Is it fresh? 125's do need more frequent piston replacements than the bigger bikes."
Hi
[/quote]
John Isherwood.
#14
Posted 23 January 2012 - 03:48 AM
I rode the p*** out of the wifeys 125 when I had it. Loverly little bike and I left it stock, but second gear at WOT was all it would pull on big hills with me onit, and I am not heavy. Add, you don't let off!
It is not a 200 and will never be. Just gotts learn how to ride the thing. It does teach you how to get the most out a bike!
#15
Posted 23 January 2012 - 04:38 AM
We where very happy with the power of my son's 2011 125 Sherco. When he rode the GG he said they didn't have as much power.
For sure put on a 48 rear sprocket. Biggest improvement. Jetting-leave in the stock 40 pilot and go with a 112 main. A S3 head with the "high high" insert helps a little, but not much. S3 header pipe didn't make much of a difference. While on that, make sure the reducer is still installed into the stock header pipe.
Chris Cullins
