Ignition Details - SWM TL320 1981 ish
#1
Posted 22 January 2012 - 07:31 PM
Timing 2.6/2.8 BTDC
Points Gap - 0.4mm
Plug Gap - ? Help !
A few other questions - How do you adjust the timing, do you need to slip the magneto off and move the back plate and refit the magneto and check. Are there any timing marks to point the strobe at ? Ours seems to have some cold chisel marks on the backplate !
How do you connect an external condensor ?
The only wiring diagrams I have found are in Italian and a bit difficult to read the colours etc.
Finally, not getting any e-mail replies from Martin Matthews. Is he on holiday ?
Many Thanks.
#2
Posted 22 January 2012 - 10:26 PM
Yes to how you adjust timing, though not that critical.
Timing mark on casing at about 11, by screw hole, and faint mark on fly wheel is there if you look, hard.
To connect an external condersor, disconnect existing and remove or isolate, join wires together, pref solder and insulate. Mount a new condensor by coil and connect black wire. I use a VW one from Euro car parts which has 2 connectors and a bracket which makes it easy. If you want the part no ask. Bultaco UK also do one thats suitable.
Martin seems to spend a fair bit of time away so not always an instant answer.
Edited by B40RT, 22 January 2012 - 10:31 PM.
#3
Posted 22 January 2012 - 10:58 PM
Thanks for that.
I have a spare condensor, with a single cable.
So, link black cables together that were connected to existing condensor. This black cable comes from the ignition coil through to the insulated side of the points.
New condensor - mount up top and earth to chassis or coil chassis, run cable down and connect to the same insulated side of the points ?
#4
Posted 23 January 2012 - 08:34 AM
(and make sure wire by flywheel cant touch anything)
Edited by B40RT, 23 January 2012 - 08:35 AM.
#5
Posted 27 January 2012 - 07:28 PM
Fitted an electronic ignition to my 320 and all points woes now gone - it works very well - managed to get another one working "over the fone" for a nice chap I met at a local trial will shortly be installing one onto a Jumbo - hope its as successful..!!! pm me if interested
Stu
#6
Posted 27 January 2012 - 08:00 PM
Stu
Hi jumbostu, tell all about electronic ignition. Didn't think there was one commercially available ?
Ross
#7
Posted 28 January 2012 - 05:23 AM
Stu
Oh yes, sounds very interesting.
We are still trying to get ours running reliably, my endeavours last weekend resulted in a sheared woodruff key. My Son ordered replacements from Rotax which, as normal, the posty takes back to his depot because we weren't in. Hopefully, the 48 hrs noted on the card means 24 and will be available this morning !
If you could share the info. I would be most grateful, we want to be riding reliably as soon as possible instead of doing a lot of spending and swearing !
Andrew.
#8
Posted 29 January 2012 - 09:08 PM
#9
Posted 30 January 2012 - 08:02 PM
cheers
#11
Posted 30 January 2012 - 09:08 PM
#12
Posted 03 February 2012 - 11:50 PM
#14
Posted 04 February 2012 - 10:09 AM
Reginald, on 03 February 2012 - 11:50 PM, said:
And yes, fitting an electronic ignition does away with the need for a condensor
Regards
David
#15
Posted 05 February 2012 - 04:47 AM
