2012 Ossa Rear Wheel Removal
18 replies to this topic
#1 digga
    New Member
  • Members
  • Pip
  • 19 posts
  • Bike:ossa tr-280i
  • Club:none
Posted 27 January 2012 - 08:59 PM
Hi there guys,well i finally have my new 2012 TR280i in the garage,if it ever stops raining i will be able to take it for a ride.Anyway getting to the chase,i went to remove the rear wheel for a wee look and check the axle for lube,drooped the chain,removed the axle and proceeded to slide the rear wheel back and what do you know,the heads of the rear disc bolts catch the inside of the calliper assembley, am i missing something here,i have had many bikes over the last 30 years but have not had this before,surely you dont have to remove some disc bolts first?
Peter.
#2 borus
    Advanced Member
  • Members
  • PipPipPip
  • 293 posts
  • Bike:OSSA
  • Club:ata
Posted 27 January 2012 - 11:49 PM
Remove the disc protector and lift the wheel straight up. The caliper comes off with the wheel. When you install, place the caliper on the disc first then drop the wheel straight down. You will see the other end of the caliper housing fits nicely in the hub which allows it to fit properly.
cheers
Edited by borus, 27 January 2012 - 11:50 PM.
#3 digga
    New Member
  • Members
  • Pip
  • 19 posts
  • Bike:ossa tr-280i
  • Club:none
Posted 28 January 2012 - 09:25 AM
cheers
Hi borus,thanks for that,i was driving to a mates place today and the thought crossed my mind that it may come out that way,some bikes the locating pin/dowel that the calipper slides on has flats so you can only slide the wheel straight back,not upwards,but not the Ossa obviously. Thanks for that,i just have to get the knack of starting this sucker,its got zero hours on it at the moment and does not want to start with any less than a dozen kicks!
Cheers.
Edited by digga, 28 January 2012 - 09:25 AM.
#4 jsp
    Advanced Member
  • Members
  • PipPipPip
  • 329 posts
  • Bike:2012 OSSA T280i
  • Club:West of leeds, Horsforth, Spen Valley, Huddersfield
Posted 28 January 2012 - 11:07 AM
i took mine in yesterday for remaping and i spoke to the
dealer about i was having problems starting from cold
(about 6-8 kicks) he tried and it fired up in 3. what you
need to do is 2 sloppy kicks and then take the slack out
of the kick start and then jump on it, i tried again last
night when it was cold again and it started 3rd kick, i am
sure i just havent been kick it hard enough. when its hot
its 1 or 2 kicks max
jsp
Edited by jsp, 28 January 2012 - 11:08 AM.
#5 borus
    Advanced Member
  • Members
  • PipPipPip
  • 293 posts
  • Bike:OSSA
  • Club:ata
Posted 28 January 2012 - 12:15 PM
Cheers.
Glad it helps. it's rather easy that way. I think because the Ossa is unique there are some tricks to working on them etc. Once riders get the knack to starting they're really no issue. The latest map appears to have more power everywhere and revs freer, same starting and maybe a little higher tickerover. JMO "welcome to the future" :)
cheers
#6 jsp
    Advanced Member
  • Members
  • PipPipPip
  • 329 posts
Posted 28 January 2012 - 01:06 PM
the futures bright the futures GREEN
jsp
#7 borus
    Advanced Member
  • Members
  • PipPipPip
  • 293 posts
  • Bike:OSSA
  • Club:ata
Posted 28 January 2012 - 01:08 PM
jsp
:thumbup:
#8 digga
    New Member
  • Members
  • Pip
  • 19 posts
  • Bike:ossa tr-280i
  • Club:none
Posted 28 January 2012 - 07:50 PM
View Postborus, on 28 January 2012 - 01:08 PM, said:
:thumbup:
Thanks you guys,yes your correct about the bike being unique and it appears there is certain ways to remove different things,(like the air-cleaner)thats a challenge,its great to see some genuine interest and mateship in the Ossa community,have not really experienced that with other brands of bikes,i guess i have never been a member of a forum either,only joined a few months back to ask some questions about the Ossa when trying to decide between it and the Gasser. Next question,how close to the frame is your kickstarter in the (folded away posistion)? Mine is nearly touching,but i assume if i were to shift it on the internal splines it will be way too forward?
Cheers again guys.
#9 borus
    Advanced Member
  • Members
  • PipPipPip
  • 293 posts
  • Bike:OSSA
  • Club:ata
Posted 29 January 2012 - 03:19 PM
View Postdigga, on 28 January 2012 - 07:50 PM, said:
Thanks you guys,yes your correct about the bike being unique and it appears there is certain ways to remove different things,(like the air-cleaner)thats a challenge,its great to see some genuine interest and mateship in the Ossa community,have not really experienced that with other brands of bikes,i guess i have never been a member of a forum either,only joined a few months back to ask some questions about the Ossa when trying to decide between it and the Gasser. Next question,how close to the frame is your kickstarter in the (folded away position)? Mine is nearly touching,but i assume if i were to shift it on the internal splines it will be way too forward?
Cheers again guys.
I've not run into any kick start installations where it was close to the frame.
Posted Image
Here is an installation guide - http://www.ossacanad...stallation2.pdf
Hope this helps - cheers
Edited by borus, 29 January 2012 - 03:59 PM.
#10 digga
    New Member
  • Members
  • Pip
  • 19 posts
  • Bike:ossa tr-280i
  • Club:none
Posted 30 January 2012 - 09:35 AM
Posted Image
Hi Borus,thanks for all that info and pics,now i can see how it works,as it wears into the rubber stop the clearance will increase i think,mine is about 1.5mm of the frame at the moment.
Cheers.
#11 sunlingkau
    Member
  • Members
  • PipPip
  • 97 posts
  • Bike:OSSA
  • Club:Hong Kong trial club
Posted 30 January 2012 - 02:14 PM
new bike is a bit more kicks, after some hours run ..... the bike will easier
OSSA
#12 jsp
    Advanced Member
  • Members
  • PipPipPip
  • 329 posts
Posted 04 February 2012 - 10:01 PM
had a strange day today
i noticed the snail cam on the brake side wasnt on the
swinging arm stop, tried to tighten up the bolt but still
no better, you could pull the wheel and move it.
i ve now worked out that for some strange reason
the rear wheel spindle is tightening on the
snail cams but that still isnt enough, i ve shortened
the spindle by 2mm and now ever thing seems ok.
but this has got me stumped as to how or
why this has happened. any ideas ?
jsp
Edited by jsp, 04 February 2012 - 10:02 PM.
#13 sunlingkau
    Member
  • Members
  • PipPip
  • 97 posts
  • Bike:OSSA
Posted 06 February 2012 - 03:25 PM
any photos ?
OSSA
#14 jsp
    Advanced Member
  • Members
  • PipPipPip
  • 329 posts
Posted 06 February 2012 - 03:46 PM
sorry no, do you think the spindle could have started to
stretch ? its always been hard to stop the brake side snail
cam from spinning when to tried to tighten or loosen the wheel
but with me shortening the spindle its stoped doing that now.
you could see a mark on the back of the snail cam which matched
the wheel spindle, so when it was tight it was like the spindle
was slightly longer than the gap in the swinging arm and it wasnt
tightening the wheel fully. if that makes sense
jsp
#15 Neo
    Advanced Member
  • Members
  • PipPipPip
  • 920 posts
  • Bike:250 2006 (07 frame)
Posted 07 February 2012 - 06:34 AM
View Postjsp, on 06 February 2012 - 03:46 PM, said:
sorry no, do you think the spindle could have started to stretch ? its always been hard to stop the brake side snail
cam from spinning when to tried to tighten or loosen the wheel but with me shortening the spindle its stoped doing that now. you could see a mark on the back of the snail cam which matched
the wheel spindle, so when it was tight it was like the spindle was slightly longer than the gap in the swinging arm and it wasnt tightening the wheel fully. if that makes sense
jsp
That sounds really weird to me too. Are you sure that you didn't leave out a wheel spacer or washer last time yo took off the rear wheel? .... Or have the snail cam's gone concave?
When you say you "shortened the spindle by 2mm" did you cut/grind the length of the spindle? .... Why didn't you just use a fat washer? ... And I can't figire out why that would stop the snail cam's turning?
My guess is that somthing is still not right if you had to do this.
Best of balance.
Neo
My Bike ....www.trialscentral.com/forums/garage/vehicle/516-sherco-250-2t-racing-red/
TRIALS....It's not life or death....It's much more serious than that!!
