Repacking Rear Silencer
#1
Posted 29 January 2012 - 11:22 PM
I was thinking it either needs the welds ground back and split open or a hole cut in the side.
Neither job looks that easy to do neatly.
I have a friend who is an alloy welder so not to worried about having it put back together, just getting it to that stage i'm not sure about.
Trying to decide if the the hassle outweighs the cost of a new one.
Cheers Al
#2
Posted 30 January 2012 - 04:29 AM
Cheers Al
Repacking Has been done using methods mentioned by folks that like to experiment, however a new one is perferred.
One may soak it on petrol and flush it out good and use a wire brush to help. This is ok if the packing is still ok. Air dry it after!
#3
Posted 01 February 2012 - 09:04 PM
I might try and flush it through, but I think it will end up with a new one.
Thanks for the help.
Al
#4
Posted 03 February 2012 - 07:44 PM
Thanks,
Sam
#5
Posted 13 February 2012 - 06:16 PM
I'm going to have a go at mine I think but will buy a new one if needed.
Al
#6
Posted 30 March 2012 - 11:12 PM
I've also read that just burning out all of the oil and opening up the perforated cores really helps too.
What about any kind of add on or different muffler that will fit in the same location?
#7
Posted 31 March 2012 - 03:38 AM
Not anything else to fit. Trick is to not let them get too grunged up.
#8
Posted 31 March 2012 - 11:46 AM
copemech, on 31 March 2012 - 03:38 AM, said:
Too late for that!
I suppose the silencer assembly is also the expansion chamber too so it is prolly tuned for the engine as well as making it a bit quieter. Mine is a bit dented on the outside face so maybe it's time for a mod.
#9
Posted 04 April 2012 - 03:18 PM
Well from what it says under your name it seems you have an 01' which doesn't have a guard over the exhaust and makes it really very easy to dent. What I did on mine was replace it with an 02' up style that has the guard on it. Of course wait till either your packing is shot or it's unuseable to upgrade so you can kill two birds with one stone on that.
#10
Posted 06 April 2012 - 02:55 AM
JTrials31, on 04 April 2012 - 03:18 PM, said:
Missed you at TTC!
#12
Posted 10 April 2012 - 07:15 PM
http://www.ebay.com/...984.m1497.l2649
I thought I'd have to have the FMF tubing expanded a bit to fit over the 1.25" OD Sherco tip but the FMF tubing is about 1" OD and I think it will slip inside the Sherco tip, once I cut it square.
I think I read that the rear muffler/chamber/silencer on my '01 125 is the same part number as the 250 and 290. This makes me think the tuning for Trials power is not as critical as MX or high revving engines. I bring this up because the OD of the silencer piping for the KX125 is the same size as the ID of the tip coming out of my 125 muffler. I'm sure a KX125 makes more horsepower than my Sherco 125 and I think that the size was a compromise to cover 125/250/290. I think the slightly smaller diameter and longer length just may help bottom end as well as taking some of the bark off of the note.
#13
Posted 10 April 2012 - 07:18 PM
I'll have to make a bracket/guard combo to keep my new silencer in place. Where did you find a newer style rear muffler? The ones I find are pretty expensive and overseas so shipping on top of the cost. I know, wahhhh.
#14
Posted 11 April 2012 - 02:57 AM
TNTrials, on 10 April 2012 - 07:18 PM, said:
Doubtfull this will ever work as there is nothing much to attach it to. At best it will look like a bulls ass sewn up with a logchain.
Parts are available in the US through your local dealer or ShercoUSA, or RYPUSA in KY, I would expect a new muffler to be around $250 ish. Do a search or if you need more doo tell. 800-607-8742 life is good! Prolly 2 days away from you via UPS.
It takes a lot of work and Tig welding precision to cut the welds and go back as original. Cost prohibitive. Yes I suppose if one had some basic skills, one could cut out the backsides of the two chambers and properly re- pack with steel wool and glass packing, Fabricate proper closure plates that overlap the holes cut and rivit them on using high temp sealer to seal them off. It has been done. Pick your poison!
Cheers,
#15
Posted 11 April 2012 - 01:30 PM
copemech, on 11 April 2012 - 02:57 AM, said:
This is the exact look I am going for! Awesome!
Cheers,
I guess that price isn't too bad. How long do new ones usually stay quiet-er?
Might you know of a thread or link that would have pictures of one of these mufflers opened up? Two chambers etc. or have you seen inside and might explain how it is laid out?
