Evo 300 4T Flat Spot
7 replies to this topic
#1 Wright4D
    New Member
  • Members
  • Pip
  • 17 posts
  • Bike:Evo 4T
  • Club:Macclesfield Trials Club
Posted 30 January 2012 - 08:16 PM
Hi All
Stripped down the carb on my Evo 300 4T last week cleaned it and put it back on. Now there seems to be a lat spot at about 1/3 throttle. Can anyone think what I may have got wrong?
Thanks
#2 Zzr14
    New Member
  • Members
  • Pip
  • 3 posts
  • Bike:Scoria
  • Club:None
Posted 30 January 2012 - 08:46 PM
Sell it to me, that should sort it!
#3 zerorev3rev4
    Advanced Member
  • Members
  • PipPipPip
  • 159 posts
  • Bike:zero rev3 rev4 cota
  • Club:richmond n,yorks ripon
Posted 30 January 2012 - 09:29 PM
View PostWright4D, on 30 January 2012 - 08:16 PM, said:
Hi All
Thanks
lower clip on needle one notch thus lifting the needle that should sort it ,did you do any other changes ,id also check fuel filter in the bottom of frame its in the banjo bolt , did the diaphram look ok
#4 rlracer
    Advanced Member
  • Members
  • PipPipPip
  • 426 posts
  • Bike:2012 Beta 250 2t
Posted 30 January 2012 - 10:22 PM
I'd suggest you pull the carb back off and go back through it to make sure everything is seated correctly and the air boots are on properly.
#5 BillyT
    Advanced Member
  • Members
  • PipPipPip
  • 363 posts
  • Bike:2012 Beta 300 4T
  • Club:Glasgow Celtic
Posted 31 January 2012 - 03:29 AM
Hi All
Thanks
Emh...... you took the carb off to clean it, that is what went wrong! :P
As RLRacer said is the best advise!
Edited by BillyT, 31 January 2012 - 06:38 AM.
#6 Wright4D
    New Member
  • Members
  • Pip
  • 17 posts
  • Bike:Evo 4T
Posted 31 January 2012 - 06:58 PM
Thanks for the advice folks I will try your suggestions, what I noticed today was after washing the bike I started it up and with the choke on there was no noticable flat spot when I revved it. I think this would point to it running a little lean am I along the right line with this ?. If it is then I think the needle suggestion will sort it out.
Once again thanks for all the advice.
Cheers
#7 zerorev3rev4
    Advanced Member
  • Members
  • PipPipPip
  • 159 posts
Posted 31 January 2012 - 09:53 PM
Cheers
correct it is more than likely lean midrange ie lift the needle one by lowering the clip
#8 Wright4D
    New Member
  • Members
  • Pip
  • 17 posts
  • Bike:Evo 4T
Posted 01 February 2012 - 07:44 PM
Thanks for the info, just re-set as per your advice and it seems ok (only warming it up and then revving it in the garage throughout the range) but it seems to have sorted out the problem.
Another good example of the forum coming up trumps.
Once again many thanks
Regards
Derek
