2012 Ossa Tr 2801
9 replies to this topic
#1 digga
    New Member
  • Members
  • Pip
  • 19 posts
  • Bike:ossa tr-280i
  • Club:none
Posted 31 January 2012 - 08:31 AM
Hi there guys,have just come back from my first outing on the new bike,all went well! Decided when i got home to drop the factory oil,removed the drain plug as per manual and got about 100mls out i guess,someone told me to just lay it over a touch to get the rest! HA;HA! Well i laid it right over on its side in the end,nothing until i stood it back upright then another 100 mls,so in total measured into a jug i managed to get 200mls (and it was over the sight glass from dealer). Not sure where they get 350mls from or where the rest is?
I have put 250mls back and its way over the sight glass.
So whats the trick to drain these suckers properly??
Peter.
Edited by digga, 31 January 2012 - 09:01 AM.
#2 HAM2
    Advanced Member
  • Members
  • PipPipPip
  • 2,708 posts
  • Bike:Sherco 290-05
  • Club:Jurreh Sinclurs.... Pheonix
Posted 31 January 2012 - 10:10 AM
Oh, oh..wasn't there a problem with the gearbox internal drain hole (not machined correctly at the factory)?
For the last time...it's not 'SUPPOSED' to have a seat.
There are two types of men in this world:-
1) Those who are Geordies and..
2) Those that want to be.
#3 jsp
    Advanced Member
  • Members
  • PipPipPip
  • 329 posts
  • Bike:2012 OSSA T280i
  • Club:West of leeds, Horsforth, Spen Valley, Huddersfield
Posted 31 January 2012 - 10:25 AM
i do seem to struggle aswell, local dealer has told me
to remove the clutch cover next time so its go two
exits. small price to pay for such a good bike in
my eyes
jsp
#4 borus
    Advanced Member
  • Members
  • PipPipPip
  • 293 posts
  • Bike:OSSA
  • Club:ata
Posted 31 January 2012 - 12:27 PM
you don't have to remove the clutch case, just loosen it a bit, crack it open and drain the oil from the clutch side. it take and extra 2 min. measure what you drain and fill the same. some people have drilled a hole in the bottom case of the tranny to allow oil to follow back and forth from the clutch to gears. This requires removing the tranny. 1/2 hour job. If Ossa wanted this fix they would have included it on the 2012 model. They did not. This has nothing to do with bad machining. You should turn over the motor to get an accurate site window reading after filling with oil. the oil flows through the clutch. hope this helps.
#5 sunlingkau
    Member
  • Members
  • PipPip
  • 97 posts
  • Bike:OSSA
  • Club:Hong Kong trial club
Posted 31 January 2012 - 12:39 PM
exactly, you don't have to remove the clutch case :agreed:
OSSA
#6 jsp
    Advanced Member
  • Members
  • PipPipPip
  • 329 posts
Posted 31 January 2012 - 12:58 PM
is there a gaskit or seal on the clutch casing ?
#7 borus
    Advanced Member
  • Members
  • PipPipPip
  • 293 posts
  • Bike:OSSA
  • Club:ata
Posted 31 January 2012 - 01:22 PM
take a look at this, will give you an idea of what it all about
http://www.ossacanad...%20Overview.pdf
cheers
#8 sunlingkau
    Member
  • Members
  • PipPip
  • 97 posts
  • Bike:OSSA
Posted 31 January 2012 - 01:58 PM
this one also good tips
http://www.ossacanad...k%20Guider1.pdf
OSSA
#9 jsp
    Advanced Member
  • Members
  • PipPipPip
  • 329 posts
Posted 31 January 2012 - 03:30 PM
good website that fellas thanks for that :thumbup:
jsp
#10 HAM2
    Advanced Member
  • Members
  • PipPipPip
  • 2,708 posts
Posted 31 January 2012 - 05:18 PM
Vorsprung durch Technik? :huh: .
Was the 2011 'drill-remedy' just an after-market customisation/personalisation procedure that OSSA offer to all it's customers?
i.e.:- Over and above the factory's original standard specification.
That would be a great piece of customer service if that were the case.
We are just talking about a routine oil change here?
