Ty175-Dt175 Crank Shaft
  • Please log in to reply
5 replies to this topic
#1 goudrons
goudrons
    Advanced Member
  • Members
  • PipPipPip
  • 314 posts
  • Bike:Beta Evo & Ossa Mar
Posted 09 February 2012 - 07:49 AM
Anyone know if the crank shaft (and con rod) from a DT175 is the same as the TY175?
Ads By Google User is online
Ads By Google
  • Ad Bots
Don't want these Ads? Why not help support TC and sign up as a Trials Central Supporter?
#2 mattylad
mattylad
    Advanced Member
  • Members
  • PipPipPip
  • 692 posts
  • Bike:Lots of old rubbish
Posted 09 February 2012 - 09:53 AM
There were two types of DT and DTMX which is a very different engine
From memory the rods are the same in the DT engine but the crank taper is different certainly on the ignition side of a DTMX.
#3 feetupfun
feetupfun
    Advanced Member
  • Members
  • PipPipPip
  • 2,163 posts
  • Bike:1963 to 1981
Posted 09 February 2012 - 11:06 AM
I have a DT175E bottom end that has a TY175 flywheel and ignition stator fitted so I guess that is one of the DT175 motors that has the same taper on the LH end.
Are you really asking if they are the same crankshaft or if their crankshafts are interchangeable?
There is nothing good or bad, but thinking makes it so
William Shakespeare
#4 goudrons
goudrons
    Advanced Member
  • Members
  • PipPipPip
  • 314 posts
Posted 09 February 2012 - 04:35 PM
yes, will one fit the other.
I see the conrod is listed as the same, and looking at the dt ones (of pictures) they look the same.
http://www.ebay.co.u...=item5d310398e2
I guess my next question is if they are the same does anyone have one for sale or a ty175 one even?
#5 goudrons
goudrons
    Advanced Member
  • Members
  • PipPipPip
  • 314 posts
Posted 23 February 2012 - 11:13 PM
What I feared, they aren't interchangeable.
As written above, the taper for the flywheel is narrower on the DT crank.
Next question is, what about the TY125 crank? Is that the same?
#6 tee_why
tee_why
    New Member
  • Members
  • Pip
  • 16 posts
  • Bike:TY175, Beta Rev3 270
Posted 24 February 2012 - 12:41 PM
Hi Goudrons, sounds like you found out the hard way. I have a DT and TY from '76, yes different in taper and length of taper. The smaller flywheels tend to be different, but similar tapers, then there is the keyway to match up. It is going to hard to find a compatible match. As Feetup has mentioned, the later DT with the 5 stud head, did accept the TY flywheel. The other thing is the Primary ratio gearing, thats the drive to the clutch. Again, the older DT and TY are the same, but the later DT is different.
Maybe one will turn up on ebay or somewhere, hope you find a TY one.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
