Don't want these Ads? Why not sign up as a Trials Central Supporter.
Sign in to follow this
Followers 0
old trials fanatic
Cota 242 Clutch Adjustment
10 posts in this topic
hi clutch on the 242 is dragging. I assume it's an adjustment issue so whats the adjustment proceedure? also whats best oil viscosity to use? Thanks guys :thumbup:
Share this post
Link to post
There's no real adjustment beyond the cable, the springs are held in by pins locating in the pressure plate, which is a weak cast item and prone to failure,which caused drag.Hopefully your issue is down to incorrect oil, Ive tried a few but found Putoline light gear oil to work best.
Share this post
Link to post
Unless you have run it dry and warped the plates, Cota's are not prone to clutch drag. Have you checked the clutch cable to ensure it is not frayed internally, or kinked / smashed.
Share this post
Link to post
Just got the bike and trying to asses wether it's worth restoring or not and it's strange the clutch feels like it's working normally i.e. when you pull it in the arm moves smoothly and you can feel spring pressure but the clutch doesnt dissenguage.
Share this post
Link to post
Plates stuck together ? Just a thought !
Share this post
Link to post
Spoke to Steve Goode earlier and he suggested it may be the "pushrod" which on the 242 is brass. I need to strip the cover off and there is a three legged device on the inside of the cover that the clutch lever presses to actuate the clutch when the handlebar lever is pulled in. In the middle of this three legged thingy is a brass rod that apparently wears and thus doesnt fully depress the clutch so it doesnt disenguage properly.
Sounds plausable so i will have to buckle down and strip it or just sell it. decisions decisions. Too many projects not enough time :blush:
Share this post
Link to post
You only have to take the clutch cover off to check the mechanism that Steve is talking about.
The brass actuator is about the same size as the one on the end of the Ossa pushrod and similarly sits in the clutch casing although they can fall out when removing/replacing the cover. With the cover off you can also see if the clutch cover plate is cracked.
Share this post
Link to post
Thanks Dave :thumbup:
Share this post
Link to post
Thinking again, does the 242 have the same type of bottom end as the old 200? If so clutch mechanism is on the opposite side to the bikes I'm used to like the 350, 247 etc. So it may differ slightly - but the principle should still be the same.
Share this post
Link to post
Its the same brass button and 3 legged spider as on the others.
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
Followers 0
