Gas Gas Txt Pro Raga Just Died
thomastomsk
hi there was wondering if some one could point me in the right direction,,,,i was riding my bike and then all of a sudden it just died,when i tryed to start the bike again it ran for a couple of seconds and then died again,,since then will not start,there was no indecation of anything wrong before this happened,i have checked fuel and air ,,,carb,,,and have put a new plug in,,,and it still will not start,,,,has any one got any ideas or has anybody had this happen to them ,,,thanks tom
Yep disconnect the kill switch. With mine I unscrewed the Plug Cap from the H.T Lead (just in case the Cap is faulty) Hold the H.T Lead 5-6mm from the Cylinder Head and get someone else to kick it over. You should be able to see the Spark jump the gap. Hope that helps.
  • 1 month later...
