hi all recently finished my project bsa c15 trials bike fitted with the above ignition system,all is well with the bike until it warms up then it develops a very bad misfire and loss of power,the engine has had complete overhaul the carb has been stripped and cleaned and all jets have been renewed just wondered if anybody has had any problems with these ignition systems as i am starting to think that the coil/cdi unit may be faulted.
thanks chris
Bsa C15 With Electrexworld Ignition
Started by deanod24, May 06 2012 03:19 PM
7 replies to this topic
#1
Posted 06 May 2012 - 03:19 PM
Ads By Google
#2
Posted 06 May 2012 - 04:16 PM
Have you looked at the spark when the engine is hot enough to play up ? It could also be an air leak causing a weak mixture or even a tight tappet.
Those Electrex world units have a very good reputation - but there can always be an exception.
#3
Posted 06 May 2012 - 05:09 PM
Depends who you talk to, I know three people who have had real problems with them - wrong polarity, timinng way out, advance curve retarding too soon and the after sales service and ability to sort the problems out hasn't been as good as it should have been.
Conversely, I know there are people who are quite happy with them.
So all I'm inferring is don't rule out the igniion, it could be at fault.
#4
Posted 07 May 2012 - 11:45 AM
Is the HT coil mounted away from the heat?
You could try running it without the primary drive cover on for a short while - so the generator part stays cooler..
I have one of these on my Bantam and its good.
#5
Posted 07 May 2012 - 03:05 PM
Hi there, Was powder coating/painting the frame part of your project? If it was make sure the coil bracket is free of paint for a good earth between the coil and the frame, also make sure there is good electrical contact between at least one engine lug and the frame. A poor earth can cause mysterious faults. All the best.
Edited by Tayld, 07 May 2012 - 04:29 PM.
#6
Posted 08 May 2012 - 04:07 PM
Good point Tayld, I always run a braided cable from a point on the engine to the coil earth bracket.
#7
Posted 11 May 2012 - 06:30 PM
hi all thanks for the posts have been in touch with a mate who has a c15 he has removed the carb from his bike so i can try it on my bike if it performs the same going to have to say its the ignition,as for paint or powder coat was hand painted didnt want to spend the money on powder coat to ride off road and get scratched etc never painted the coil bracket so should have a good earth, but do think i will find a way to get a better earth as that idea sounds like a good idea,
cheers chris
cheers chris
#8
Posted 14 June 2012 - 08:00 PM
Hi all , Just read about your ignition problems and it was the same trouble as my brother was having on a b40 with elextrxworld ignition. We tried all what has been said and the problem was still the same. Fed up and about to retire from yet another trial a fellow bsa rider asked if the plug gap was set to the correct thou, It was and he said that was the trouble. Open the gap a lot more was his solution. Bingo no more trouble a perfect running b40. Hope this cures your problems as well.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
