Good Step Technique ?
He needs to hit his front wheel into the rock. In the video it barely even touches wich is not a problem on that step because the rear wheel just rides straight up. If there was even a little bit of negative on the bottom his rear wheel would have been caught up. But if he hits his front wheel into the rock the suspension will compress and with a second blip of the throttle (or clutch) the suspension will decompress and place the front and back wheel onto the rock.
