Beta Techno Linkage Bearings
jon015
Had some vertical play on the swingarm. So pulled out the linkage that mounts to the shock. Needle bearings are pretty destroyed, anyone know the code for these and it is two needle bearings sat next to each other?
I don't know the numbers but have you tried looking on the trials and tribulations site?
They list parts and the numbers. Once you know the numbers get them from someone like Hayley Bearings at a fraction of the cost and get double seal ones if possible.
Use Silkolene water proof red grease when you reassemble and it will last ages before servicing again.
See here http://trialstribulations.net/index.php?main_page=product_info&cPath=34_66&products_id=909
Edited by pindie
