Sign in to follow this
Followers 0
darrenc
Electronic Ignition
4 posts in this topic
has any body put electronic ignition on a 250t ?
this bike has motoplat ignition and can't get the timing right it fire ring about 10 deg before TDC and now more movement on the back plate .
Thank Darren
Share this post
Link to post
when should it fire , are the parts standard
Share this post
Link to post
the book said 2.7 after TDC and the points are at 40mm. i'm using a strobe light to check this is this the best way to check it ?
Share this post
Link to post
Hi Darren. The best way to time an Italjet is to use a multi meter and a dial gauge. You hook the multi meter up to the black ignition wire going to the coil and to earth and put the dial gauge in the spark plug hole and get the points to start to open at 2.7mm BTDC. You will see on the multi meter when the points start to open. I hope this helps you out. Graham.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
