Bsa B25 Clutch Operating Arm
wallo
The small pinion which acts upon the rack is fitted onto the spindle with a left hand thread, if you leave the pinion in its recess and TAP!!! the arm in a CLOCKWISE direction it should come loose.
To fit it back on, fit the bits together and hold it in soft jaws in a vice or "G" clamp and again TAP in the opposite direction just to lock it up.
And as Whinger said "BE CAREFUL"
Good Luck
