Fantic 240 Drain Plug Size
redhubuk
Fantic 240 Drain Plug size, my latest purchase has a horific epoxy repair around the drain plug. I'm not even sure the plugs standard, so would like to know original size so I can have a go at proper repair and try and use original size. M12x1.5 pitch ?
Many thanks
My mate's 156cc Fantic thread started to strip and he couldn't get the original plug to seal. We tapped it out to M12 x 1.75 (standard pitch) then got a hex head M12 bolt and machined the head down to 3mm thick and tapped a M6 thread through the centre. He then cut the thread to the required length and bonded this into the existing drain plug hole.
When then sourced an M6 pan head and a 1/8 BSPP bonded seal (dowty seal) and this screws into the permanent plug that allows you to drain the oil and seals really well.
Note, all bolts are stainless steel.
Cheers...
