Sign in to follow this
Followers 0
jap350
78 213 Alpina
49 posts in this topic
Andy, You have been busy and unavailable lately, hope no illness has found you.
Do let us know how you get on.
Larry
Share this post
Link to post
On 12/3/2014 at 0:30 PM, woody said:
You can't back the nuts off very much as they will foul the inside of the case, so I machine the nuts to half of their thickness.
Woody, thanks for the really informative guide!
What size are the original clutch basket nuts? M8x1.25 full hex nuts?
If I replaced them with a set of jam/lock nuts, would they be thin enough? M8 nuts are 6.8 mm jam nuts are 4 mm...
Share this post
Link to post
Those nuts are specials with a reduced OD (smaller than the A/F dimension) on one end to locate inside the spring so if you use some other nuts you will need to machine the recess. I'll measure one up later and post the info up if no-one else does first
1 person likes this
Share this post
Link to post
The smart thing to do would be to leave the nuts the full width but make the machined section wider, so it spigots more deeply into the spring. You'd hold the nut on a threaded mandrel to machine it.
1 person likes this
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
