Fantic 300 Sprokets
alberto
Back in the 80's most people put a smaller gearbox sprocket on. 13t is original, many went to 12t (as I did on the 300 Fantic I had in 1984)
I seem to recall 11t being used too.
I still have the standard gearing on the 300 Fantic that I now own, but I use the clutch a lot !!
Edited by rosey
today i tried 12/43, it's better
the only problem is the difference between 1° and 2° gear, like the 240, first gear is slow second gear is fast
the 305 has 1-2-3 more close but it's a 1989 bike
It's important to match your gearing to the sections you are riding in,When I set my gearing to ride the sections designed by the TY175 Yamaha guys first gear runs out so short it's only good for flat,tight sections,and second is still to high/fast,If I gear it a bit taller it first gear becomes much more usable,My clutch is a match for modern bikes so it can be used to negotiate the tighter sections and still have a longer pulling range for uphill runs.Running 11-44(I can't recall for sure the rear sprocket but that sounds right) I may swap on my SWM rear wheel and give even taller gearing a try,It's got a 39 tooth sprocket I think. Sorry,don't know the gearing on a 300 but the point is experiment until you find what works for you.
