Just To Double Check...
elliotsdaddy
Hello all.
I am in the process of changing my fork seals...all is well but just wanted to double check something.
I have just done the right leg so far, so i filled it up to 60mm from the top of the fork tube as recommended, with the fork in the bottom position.
I pumped the damper a few times and then topped up to the same level.
Is this correct or should I have just left it and not topped it up after I pumped the damper?
I think I've done it right as there really wouldn't be that much oil in the tube otherwise, but I just wanted to check....pretty new to this kind of thing.
Many thanks,
Chris.
