Sherco 250 2003 Model Fan Problem
niallpeters1
Fan runs on 12V DC. Ac output from magneto lighting coil(yellow) is connected to both a rectifier and a regulator(square and rectangular boxes) and if either is faulty fan will not run. If regulator is shorted out it will earth out the voltage.
Then you have the thermo switch(which I suppose you have jumpered), and finally the fan motor must have a proper earth.
Upon further thought I will place an addendum, as I believe the regulator can be temporarily disconnected from the system for testing, but only at idle as its job is basically to shunt off excess voltage to earth at revs, as the faster a mag spins the greater the voltage created. Output is limited at idle normally, but revving and excess voltage may not be good for things.
Once warm, the bike should start and run at idle even with tank off. With thermo switch jumpered fan should run immediately if things are right.
Edited by copemech
