'15 Evo Ignition Map Switch
dorian
I just bought a '15 Evo 300. Manual says that map switch depressed is "hard" map (sun), normal position is "soft" map (cloud).
However the sticker on the switch itself says the exact opposite from the manual. Anyone know for sure which is correct?
Not critical I guess since my skill level isn't at a point where I can really tell the difference between the two settings - or maybe there isn't an appreciable difference? Just curious mostly.
Thanks, Dorian
The only map switch I've used that makes a marked difference is on a friends 05' 4rt with a 300 kit and a trick ecu ... in the soft position it's like a tl250 with a bunch of extra torque , in the power position it's kinda like a well tuned XR500 ... aka hang on !
Glenn :)
