Water Pump Seal
itstommmm
Normally seals work that you put the spring towards what you want to keep in (towards pressure). So in case of a crank towards the crank (you dont want it to leak out pressure), in case of a suspension you want to keep the fluid in so towards the lower fork (except for up side down fork lol).
So most of the time you should be able to reason how and why a seal should be mounted in some way :)
Edited by crazybond700
