Keihn Carb Settings 250 Sherco
fred 16
My friend is having a nightmare with his Sherco 290 fitted with a Kehein, running very inconsistently with intermittent rich/weak running. He said there's volumes of info on setting these up on forums. I suggested he test the Keheins aerodynamics and see how far it flies. Waiting now to see how it runs with his replacement Dellorto.
Mine 300 has Keihin. Not the easyest to set but now runs greath.
Much more easy to keep in rear wheel in 5th gear! (than my previous 2.9)
<the air screw is only 1/4 to 1/2 turn>
Edited by cascao
Check the jetting then, should be around 45/125. A 28 Kiehin is larger than the stock 26, and even though the carb works fine, it may be a tad on the large size for 250 when doing quick "whack" opens of the throttle. Do you ride like that? No, then no issue!
