Difficulty Engaging Neutral
malcolm
The shifting is adjustable on the clutch side. There is a smal allen screw behind the clutch.
FOr more info see https://www.youtube.com/watch?v=EAHsCv647B8
I must say they are always difficult with these bikes, and I cant really care. Kick engine on in neutral, select gear to ride, and shut it of in gear...
Edited by crazybond700
I haven't found a trials bike yet that is easy to get into neutral with your foot while running. I Usually do it by hand or just switch the bike off in gear.
If you can find neutral easy you will be sure to find it while your halfway up a hill too!!!
Your clutch may be starting to drag a little. They are a lot harder to find neutral when there is a slight torque through the gearbox. A sharp tap with the heel when in first usually works
