Model 10 Frame
blutaco
I've just acquired a 1966 Model 10 for restoration that has had its bottom frame loop sliced off and replaced with a skid plate. I'd really prefer to restore her to a good old fashioned bottom loop. The 4 speed engine of course has its third engine mount below the gearbox so at the moment all these 18 Bultaco HP's are suspended by 2 bolts only. Is a replacement frame (hen's teeth?) my only option here?
Sounds like a major exercise to restore the frame to original but a decent fabricator could do it with pictures. The chances of finding another model 10 frame are next to nil
Or you could get a better bash plate made and bolt a bracket to that for the bottom mount, as they did with the Beamish Suzuki
You are confirming my fears, Woody! The poor thing has been butchered and I would like to give her my best shot. 'Parting out' is a crime so that's not an option. I acquired a M49 frame at the same time as it was suggested that it could be a dobor for the bottom rail but I could not do that to a good frame! This is turning into Challenge Aneka!
Where are you located. I am located in North Essex (UK) and have a Model 10 frame you could come and take measurements from. An actual model 10 frame is hens teeth but the lower loop from several other early models fitted with the 4 speed engine are similar if not identical so could easily be grafted in place by a competent welder. The first matador, model 16 frame is basically the same frame with additional webs.(this model was developed from the model 10) If you could get one of these frames they can easily be modified to model 10 standard. More than one model 10 has been rebuilt with a model 16 frame.  I was told this by Dave Renham but I suspect actual owners will not be so forthcoming. I have a model 16 frame (not for sale) and I have measured it side by side with the model 10 and can confirm the main loop has the same geometry including head stock angle.If you are in the UK and able to visit you would be welcome to see the two  frames side by side.
In other words this is probably not as difficult as you might think. Please do it.
Stuart
Ok. Sounds encouraging, TS. I'm in Scotland and not particularly mobile but photos would help. Even if I left the crankcases in situ, that would form some sort of jig for a frame builder to work to. When I was a young lad this is the sort of problem I had wise older heads to turn to. Thank God for the Internet!
Blutaco .
I will sort out some photographs and send them to you. It will take me probably about a week to find the time to get the frames out of the shed and  take the photo's. Could you PM me an email address to send theses to.
I have to be honest with you my M10 frame is very rusty in this lower loop area and I am a bit concerned about it strength. This is why I have the model 16 frame as I intend doing a similar task as you propose. It is also why I have measured the two frames side by side. I started on my Model 10 project about 3 years ago but it has been side lined as I am working on restoring a BSA car, Hopefully will be back onto it next year.
The model 49 frame will provide donor parts but I think they changed the size between the 4 speed and 5 speed engines so will need more work than a model 16 frame. When I take the photographs I will try a set of model 80 crank cases in to confirm my suspicions.
Stuart/Twinnshock.
Blutaco,
       I also have a Model 10. There are pictures of the frame on my Old Bultaco post if they are any use to you. If you want I can take measurements for you of the areas you require.
Good luck with it.
Larry 2.
Photos and measurements would be good, Larry. I'll concentrate on the engine first, though. Looks like I'll have source a crankshaft as the main bearings slip on and off far too easily. The conrod has a bushes small end instead of needle roller so it looks like the engine has been hastily put together with odds and sods and never fired up. Bit of a challenge, this young lady!
