Montes A Cota 200
sprite125cc
Common practice on Montesa's is to disconnect the stock unit in the backing plate. Purchase any good automotive condenser and mount and ground it between the frame reinforcements in the headstock. Splice the condenser wire to the hot wire from the coil. No more heat failures or pitted points.
