Gas Gas Txt 250 (2000) Service Manual?
smiler
Don't think you will find one unless someone has one that came with there bike, but this might help.
Spark Plug
NGKBP5RES, Champion RN11YC, Bosch Platinum WR9DP
Trans/Clutch Oil
Always 5W30 (Not 10W40), 650cc  normal motor oil (Castrol/Penzoil etc). It is not recommended to use synthetic oil.
Gasoline
95 Octane minimum.
Premix
Between 80:1 and 100:1
Brake Fluid
DOT 4 is standard. DOT 5 is fine. (All higher numbers mix with lower numbers).
This was taken from A Gas Gas site.
Also loads info here http://www.trialspartsusa.com/tech.html
Edited by bilks
There's not one for the 280 either only the parts list for that year.
Well spotted.  I'm pretty certain they used to be on that page and took it for granted they still were; sorry.
Edited by lowbrow
