Programmable Throttle Body Part Numbers
chris200
Hmm that complicates things!! Im sure somebody on here will have the answer for you. Good luck and post how you get on please il be interested in how they can be identified.
Just a quick update for you , I've overcome the problem by buying a PTB with the part number ending 315 which is known to be programmable  :hyper:
Now I need to locate the cables and software to change the map , The "Fujigas" map currently on the new unit might be a bit of a handful for a 49 yr old wobbler  :blush:
I'm hoping the software will also show whether my old unit is also programmable .
Despite lots of searching I've not found any references to any form of usb slot on the PTB and all seem to use the main wiring loom for programming , Maybe the usb slot is only on the works bike to enable "on the fly" programming via usb ?
