2003 Rear Wheel
guy53
New rubber strap, but you need to check the condition of the rim first.
PS. It also depends on how fast it leaks. Each week it needs air or every couple of hours?
Edited by lineaway
You might want to check where it's leaking from first.
Pump it up to around 30psi and spray around bead and around the spoke/nipples with soapy water.
They can seem to hold air when you aren't riding, only for them to lose pressure when you ride.
This is often caused by loose spokes allowing the rim to flex too much.
You can often stop it by nipping up the lose nipples, but as it's a 2003, it might be due a wheel truing.
It could also be down to corrosion around the inner rim, I've seen quite a few crusty alloy rims that have scabbed and flaked up around the inner section.
If it's not too bad, a scrub with a fine wire brush will remove most of it.
Once you are sure the spokes and nipples are tensioned and the inner section clean, fit a one piece inner rim band, one that has the valve bounded to the band.
You have to lube the band and inner rim up well with soapy water, so the band snaps in place and evenly tensions it's self in one go and you haven't got to poke and prod it into place.
If it doesn't snap into place first time and bunches up, it won't sit straight, so it leaks again!
Edited by goudrons
