Ossa Mar Spark Plug....and Other Stupid Questions!
basketcase
After almost 2 1/2 years rebuilding my '75 mar I'm almost nearing completion!! The spark plug in the bike is a Champion RN7YC and a NGK 6 ES came as a spare. What is the recommended (best) plug to put in?
Now for the really stupid question.....how many gears should there be? I'm more used to jap and Brit bikes, well that's my excuse! Oh, and which way do they shift, 1st up or down?
Cheers in advance.
If your clutch is stuck (pretty common)- tie the lever to the bar and let it sit.
If that doesn't work, then start the bike and warm it up- then hold the clutch in, push the bike a bit so you can slide it I to gear.
Go about 10mph and stomp on the brakes, while holding in the clutch.
