2003 Txt Pro Clutch Issues - Please Help!
bron yr aur
This is my first venture into the clutch, so sorry for my ignorance. I've seen online where they're in 2 parts, but mine looks a little different, in that from the outside view, it all looks like one piece. But absolutely nothing moves. The entire assembly is stuck in there. And like I said, I even had about a 3 lb slide hammer, giving it fairly firm whacks on alternating sides. I hooked the hammer under the retaining ring with the discs out, so that I didn't risk damaging it. I'm baffled.
Maybe you tried but I will sthttp://www.trialscentral.com/forums/index.php?app=forums&module=post&section=post&do=reply_post&f=7&t=60347&qpid=427209illexplain it a bit more extensive, maybe it helps.
Remove the 10 bolds, round ring with the 10 holes, the spring, all the fingers, dont forget the inner bold with the small whole. You should be able to pull the inner clutch hup out now.
Should look like this. Then the outer parts should come free aswell.
It could be that the plates are a little bit twisted, or the clutch basket is a little worn (the plates hit the grooves), and then they might be stuck in there a little.
(a random picture but it shows the wear good i am talking about)
64825d1350170922-clutch-drum-basket-wear
Edited by crazybond700
Sorry, I must not have explained well before. I did get all the clutch discs out before. That's how I was able to sand them and get them into spec. Then, with all of them out, I reinstalled the ring in order to have something to grab onto. Nada. I also used pry bars against the case. It just won't budge.
Sorry, I must not have explained well before. I did get all the clutch discs out. That's how I was able to sand them and get them into spec. Then, with all of them out, I reinstalled the ring in order to have something to grab onto. Nada. I also used pry bars against the case. It just won't budge.
Thanks so much for the pics.
Edited by bron yr aur
