4Rt Showa Fork Oil Level Adjustment
oz thumper
With the standard oil levels as per manual I find the forks pull up fairly suddenly on compression and are not reaching full stroke during a ride.
I am thinking of reducing the oil level slightly to reduce the air spring pressure on full compression.
I presume the left (spring) leg is the one that controls the final stroke, is that correct??
Have any light weight riders reduced the oil level and if so how much??
