Gear And Brake Lever Swap Over
mudyman
Hi all,
has anyone got information about a swop over from left to right for the gear lever / brake lever ?
Theres a pic of Walter Wolfs bike www.bonhams.com/auctions/16535/lot/350/  which shows them changed over and I found  a pic of Bernie Schreiber with this change over ftted.
  • 11 months later...
Hi mudyman,
My T350 has had change over done but know nothing about when or how it was changed but should be able to contact previous owner see if he has info and pass it on to you, I just signed tonight and hope to post some pics of  my bike soon. Tug.
When the bikes were originally on the market in the early eighties you could buy a complete kit [from the manufacturer] to convert them over.From memory it included a gear shaft that went all the way through the engine and came out though the primary cover, there was a bung in the cover that was tapped out revealing the pre drilled hole. The kit included a brake pedal and all the necessary parts. I don't remember putting a seal in the primary cover but it is a long time ago.If you have some engineering skills it wouldn't be that difficult to make the shaft, the shifter spline would be the biggest hurdle.
Cheers Greg
  • Like 3
