Clutch Not Disengaging
bultaco82
I have a 2011 Sherco 290 and I'm starting to have trouble with the clutch. The clutch pack is the original and now it does not release predictably. In a section when I pull the clutch lever in, I have about a 15% chance it will keep pulling for another 2 to 4 feet before releasing. If it were a GasGas ,I'd say the clutch pack had swollen. Would this be the case with the Sherco pack also or are the plates just worn out? Anyone else experience this? Thoughts or ideas? Thanks!
Clutch basket will be worn where the tabs on the plates meet the basket. Strip and either file smooth or replace
Personally if the basket has grooves I'd just replace it, they are really cheap & splatshop has a post in their blog on the website showing how to do it which isn't a hard job
I replaced mine a couple of years ago & the new rubber dampers made the motor sound like new again
Look at the clutch fix pinned at top of Beta forum. Also dressing the steel plates with fine emory cloth may help as the steels get polished and can hydraulic lock (suction) if they are too smooth. You may also have a damaged plate. Sometimes the forged aluminum fiber plates crack.
Thanks for the replies! Oil is changed often and a was done a week ago. Sounds like I have to open it up and check for a notched basket or polished plates. I did the Beta fix when I bought the bike (used)and filed the fingers then. Thanks again!
