Whine On A 2013 300Cc Factory Replica
jsp
Does the pump cover get very hot? This is why I asked about coolant Color as I had an issue once with the plastic pump impeller rubbing on the pump case which made a funny noise, and eventually ruined the pump.mperhaps the noise is more apparent at a certain revolution range such as produced by second gear. To correct this I noticed that there was no gasket on the 300 between the casing and waterpump although one was listed in the parts book. I made a thin one from gasket material (because of the wear I ultimately replaced the pump as well as the fins had worn down) and the issue was totally solved.
