beta rev 3 clutch problem :(
jonny 1234
 So you are riding it and cannot shift? Or is the clutch just not working? The plates stick on a Beta. Either ride it around with the clutch in and use the brakes till it releases. Or just rock it back and forth with it in gear before you start it. Always point the bike in a clear direction.
Hi Jonny,
when you pull in the lever does it have any resistance and return after you release it or does it just pull in and stay?
Beta's have a notorious clutch stick when cold that can be fixed by cleaning up the fiber plates. The fix is pinned at the top of this forum.
