Help gear oil leak from clutch slave
pete_d
Appreciate any advice on this.. I have a gasgas jtr 160 was out on it yesterday had great day got home and it had leeked atf all over my van.. cleaned it up and seems to be coming from clutch slave cyclender meets engine.. most of it has probably leaked in to sump guard while riding and then leeked  out on my van floor.. topped up and not leaking while in garage so must be when clutch is operated.. is their a gaskit or seal behind this don't want to pull it apart if it's a complex job but if it's easy enough will have a go.. thanks for any info
Happy new year!
Hi lineaway..  not had it long when I first got it dropped the oil and put 650 of atf in was showing half way up on sight glass.. the amount that has come out looks like is empty.. where would I find the overflow?
