oneal121
1997 jtx 250 help
Hi all, i need a little help my new to me gas gas jtx 250 as had a few minor problems. The throttle cable looked to be routed wrong running up the right hand side of the bike and out through the front of the frame with a big loop behind the number board. Can anyone please let know the correct throttle cable route.
Also should the correct spark plug should it be  a BPR5ES Or a BPR7ES as  im getting conflicting information and my old spark plug is unreadable.
\Thanks for any help in adavance
Share this post
Link to post
To the left[ if you are stood on the bike]  with the throttle cable and if you still have a big loop/excess then its the wrong throttle cable.
5 is the plug heat number as standard. iridium is best although a lot of people will say that there are no problems with a standard plug.
Share this post
Link to post
The stock plug is a #5 but if it fouls easily, go to a #7.  Its a good idea to carry a new,clean plug and wrench (spanner) to change it when it fouls.  Note I did not say if, but when.
Share this post
Link to post
Unfortunately there isn't really any workshop manual.  One of the best resources is the set of youtube videos made by Jim Snell when he was the Gasgas importer.  Search there or on google by his name or even GasGas maintenance and it's easy to find them.  Good luck,  Keep the rubber side down and the feet up!
Share this post
Link to post
A little late but maybe think about this. BPR is an NGK. Going from a 5 to a 7 is two ranges colder. If you are fouling plugs with a 5, the 7 will be worse. If you are fouling plugs on a trialer there is some other issue than the plug that you need to fix. Good luck.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
