Front brake issues
dmc2028372
My mate has an 07 beta rev 3 250. After half an hour or so the front brake starts to bind and gets gradually tighter until the disc is really hot. At this point the lever is tight.
Any ideas? We've retracted the pistons in the calliper and dobbed them in grease and they seem fine! Where do we go from here?
As above. The master cylinder has a hole that allows fluid from the reservoir to replenish the system when the lever is fully let out. When you use the brake the fluid gets heated and expands. Normally not a problem as the pressure in the system is relieved every time the lever is returned to full rest and the hole is uncovered releasing the pressure into the reservoir. Some people will try to get the lever to stay closer to the bars by tightening the set screw that adjusts the lever position at rest too far. What happens is the piston in the master cylinder never returns all the way to the rest position so it never uncovers the hole to the reservoir. Pressure builds up in the brake system causing brake drag which makes more heat which builds more pressure which causes more drag.... Eventually the brake is stuck full on and the lever won't move. This can also happen if the hole to the brake reservoir gets blocked. There have been reports of cylinders with debris or misdrilled holes but I'd go for the simple solution first and check that when the lever is at rest the piston in the master cylinder is returning all the way against the circlip. Same thing happens on the clutch side though in that case it causes clutch slippage.
