Sign in to follow this
Followers 0
malcolm
Gear lever return spring
7 posts in this topic
The gear lever on my sons Sherco ST 125 (2015) does not return to the central position when he changes gear. I checked the gear return spring but it is not broken. Do these springs become weak so become ineffective. Would it be an idea to change the spring while I have the clutch casing removed. If the problem is not the what else could it be.
thanks
Share this post
Link to post
Do you think the selector shaft is bent?or maybe the weld is damaged at the end of the shaft?
Share this post
Link to post
Do you mean the shaft the gear lever is attached to. If so, it seems ok.
Share this post
Link to post
Yes that's the bit.what about a picture or a video to show us what's going on!
Share this post
Link to post
Change the spring, they weaken then crack.
Share this post
Link to post
 The only way to check the shaft is to remove it. Also the pins on the drum the selector connects too can break.
Share this post
Link to post
Pins on the drum are ok and he shaft is straight. I'll change the selector spring and see if that solves the problem. Thanks for all the replies.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
